lawrosa
Feb 01, 2018Explorer
scubadvr wrote:BFL13 wrote:
If your WFCO is fried, this is your chance to get something else, such as that PowerMax I linked earlier. WFCOs have "issues" so you could be back here about those pretty soon, even if you get a new WFCO the same as that.
If I switch as you recommend, what about the breakers? The fried WFCO is a power center with 12dc and standard breakers. Sorry for all the questions, new to the RV thing.
I just replaced mine. Get the wild cat.. Ill put a link... It fits in the wfco space... BFL likes that other one he listed but you need to mount then elsewhere. I like simplicity...
You can probably get a 55 amp in there as they are all the same size...
As stated call randy at best converter..
Ummmm did you check the fuse under the trailer? There should be a fuse or breaker somewhere from battery to converter along that wire...
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
