scubadvr's avatar
scubadvr
WFCO converter keeps blowing 30 amp fuse
Hi,
Very new to here and a recent purchase of a used '13 Jayco Swift SLX 154bh. I am having an issue with my converter. I have the WF-8735-P. Everything was working fine until I had a 30 amp outlet installed out side my house. The first time I plugged into the new outlet I heard a pop from the converter. The 30 amp fuse for the power keeps blowing. I disconnected from the battery and tried just plugging into the outlet, nothing. Battery still disconnect and used an adapter to plug into a standard house outlet, nothing. If I hook up the battery again and try to connect the fuse, I get sparks and the fuse goes again. I have now blown 5 fuses trying to track the issue down. Any help would be greatly appreciated.
  • Suspect yet another 30a outlet was installed with 240volts instead of 120v by an electrician with no clue about RVs.
