You can connect Hoover Dam to a flashlight battery and as long as the VOLTAGE is regulated you are going to have a happy battery.
Lots of confusion about voltage and amperage here on this forum. I try my best to add a paragraph so as to try to keep things clearer when responding.
VOLTAGE CONTROL is MORE crucial that amperage capability. "More" has a definition.
The water analogy works here
PRESSURE is voltage
GALLONS per hour is amperage.
An RV water system would not like 200 PSI.
An RV water tank would not like to be filled at a rate of 500 gallons a minute.
"BOOST" Which idiot came up with that buzzword?
