joeshmoe's avatar
joeshmoe
Explorer III
Aug 20, 2014
WFCO Converter Longevity
I've been reading that these things are pretty much junk, don't last long. How long can I expect to get out of it? What should I upgrade to? For the time being, I'm thinking hooking up a battery tender directly to the battery. Suggestions?
  • I had 2 and a friend had 1... they will not boost nor put out any amps. The electronics (capacitors in the primary of the switcher have dried out... A common problem after 3+ years. I nor my friend elected to fix or replace with like... I replaced mine with a Progressive Dynamics 9260. Have had it for 10+ years and it still works...
    Jim
  • Seven years and still working (except boost mode) on the one in my Northstar.
  • Hi,
    The problem is with them going into boost mode. Use it until it fails. It might last for years.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
