bjarnold's avatar
bjarnold
WFCO Converter
On our last trip when plugged into 30 amp shore power the converter would turn on for a few minutes and the interior lights would brighten then go dim once the converter shut off a couple minutes later. I had the batteries checked and they were bad so I replaced them. The problem still exists so it leads me to believe the converter board is shot. Should I get a 35 amp or 45 amp?. It's a travel trailer with two 12 volt batteries
  • Randy at Best Converters has several slide in replacements for the WFCO. Easy to swap out and he will guide you thru it if you need help. clicky
  • It seems that it goes either into smart mode or boost mode only. Full charge when the lights are on or nothing
  • RoyB's avatar
    RoyB
    Explorer II
    You will want to get a smart mode converter/charger unit...
    ALot of folks have problems with the WFCO products ever going into smart mode charging... I would replace your WFCO unit with a Progressive Dynamics or IOTA unit that will always work in smart mode when required...
    If the charger never goes into smart mode charging it will remain at 13.6VDC and is known to boil out your battery fluids resulting in battery failure unless you do a very regular Battery maintenance inspection routine...
    Read up on the WFCO products not going into smart mode sequences...
    Roy Ken
  • 35 or 45 or 55 or 60 amps is fine. DO NOT spend money on a WFCO.
    Get a Progressive Dynamics or IOTA replacement. Especially if using a generator to recharge.
    Boondocker is fine for plugged into utility power.
  • Make sure all the connections are good but that is the absolute classic symptom of a converter going bad.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
