At the suggestion of a member I tested my converter with the following result: No shore power, no generator: 12.2VDC Shore power (110VAC) : 12.5VDC Generator power : 12.5VDC ...
The battery voltage went up so that means the converter is working , likely at 13.6v. Wait a couple of days and the batteries should be recharged with the voltage at 13.6
Then remove 120v input to the converter and battery voltage should drop to about 13 and then settle at about 12.75 (or less if they are sulfated)
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
