KoberExplorerNov 30, 2017WFCO ConverterAt the suggestion of a member I tested my converter with the following result: No shore power, no generator: 12.2VDC Shore power (110VAC) : 12.5VDC Generator power : 12.5VDC ...Show More
Old-BiscuitExplorer IIINov 30, 2017Need to disconnect battery cable at converter and then test converter DC outputW/O Battery connected converter DC output S/B 13.2V DC MINIMUM and SteadyIf lower then converter is failingIf 13.2V DC Min then need to test battery cell voltages and specific gravityNumbers posted just indicate a low batteryAnd WFCO Converters FAIL routinely----NOT an internet mythHave tested/replace several due to bad capacitorsLow quality junk
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related ContentWFCO converter questionWFCO 8875 converterWFCO 55 amp converter operationShould I Change My WFCO Converter?WFCO Converter Longevity
