KoberExplorerNov 30, 2017WFCO ConverterAt the suggestion of a member I tested my converter with the following result: No shore power, no generator: 12.2VDC Shore power (110VAC) : 12.5VDC Generator power : 12.5VDC ...Show More
pianotunaNomad IIIDec 01, 2017Judge the wcfo.Does it operate as advertised?No.So once it starts to fail should it be replaced with another wfco, or should the owner upgrade?Upgrade.What is best for the battery? Temperature compensation or not?Temperature compensation.Your batteries will thank you.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related ContentWFCO converter questionWFCO 8875 converterWFCO 55 amp converter operationShould I Change My WFCO Converter?WFCO Converter Longevity
