RoyB
Jul 13, 2020Explorer III
howardwheeler wrote:
Your experience is mine, and I remember having a Progressive Dynamics converter in one of my travel trailers. I think that might be what I ought to do. So your PD converter did drop into float?
That is what worked well for me to keep my three 12VDC BATTERIES charged. My setup has lasted up to 2016 where I have not used my POPUP much now due to family issues.
Recently I have updated my Battery Bank to two groups of two 6VDC batteries in series and will be using a 59-inch TORKLIFT Battery Box with slide off lid across the tongue of my POPUP. It fits perfect inside the welded on battery rails and extends out on both side of the tongue area.
Have been using the same Progressive Dynamics Charger on the work bench to keep the new batteries charged and it works well... The TORKLIFT box came with a 10WATT Solar Panel on one end and I am planning to order a second 10WATT Solar panel for the other end. This will be a solar panel for each two group 6V Batteries. This is for trickle charging of the two groups of 6V batteries during the high sun days...
Hoping to get back into my off-road camping trips again mainly here in Virginia and along the VA/WVA wooded state line borders.
Since my OFF-ROAD POPUP trailer has been sitting outside I notice I now have water damage to one corner that will have to be addressed... The trailer was sitting at an angle and runoff of the roof on the dropped side apparently got inside the wall... No damage done to the outside just inside wall damage and the rear panel separated at the BUTYL seam Don't think this is going to be a difficult fix... This is in the wrap around seating area so should be an easy access from the inside..
Roy Ken
