Timeking
Jun 25, 2021Explorer
Parasitic draw on my 2018 Rockwood 2606WS TT is 0.33 amps, which is apparently sufficient to keep the WFCO at 13.6V. Yes, I could turn off CO and propane detectors ... risking not turning them back on. Bad idea that.
So the question is "does any converter drop to 13.2 over a 0.33A parasitic draw"? I'm thinking not.
Although posts above say 13.6 not a problem, but 13.6 did burn up a battery when I didn't check the water level for 3 months. At 13.6 I can see slow out-gassing going on in all the cells. It would be nice if there was a button I could press and the voltage would drop to 13.2, overriding all this 'automatic' techno babble that doesn't actually work on modern RVs.
