whymelord's avatar
whymelord
WFCO Fan Thermostat fix
Good day all.
I've been searching through this and other forums looking for a fix for the bad cooling fan thermostat on my WFCO 8955 converter with no luck. The converter is putting out power properly (as good as the cheap WFCO can) and I know the best thing to do is to replace the whole think with a good PD converter, but I can't rationalize spending the money at this time if I can get my soldering iron out and replacing a part or two.
Other than "throw it out" or "put it on the bench" does anybody have any advice/knowledge about how I could fix this puppy?
Thanks for any and all comments/help.
  • Why not just bypass the thermostat and keep the fan running all the time? Hooking it directly into a 12V source should do the trick. You probably won't even notice the small muffin fan running unless the converter is located right by your bed.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
