MEXICOWANDERER
Sep 25, 2017Explorer
WFCO factory length red and white cables with soldered ring terminals. Battery at 12,2 volts. Connected cheese grater 100-amp load tester. Drew battery down to 10.8 volts, released button and simultaneously flipped switch for WFCO.
13.6 volts.
A couple of times starting at 12.2 volts the WFCO went to 14.4 volts for a couple of minutes.
The unit provided great amusement. Then one day it hiked its skirt and went "poof". The next thing it knew it lay on the work bench getting a hysterical-rectum-ee, The 5/16" thick, heat stink was lobotomized. A near finless block of aluminum pretty much describes the mentality of this failed childbirth.
13.6 volts.
