lawrosa's avatar
lawrosa
wfco possibly issues Bulk mode..Charge abilitys?
I have to say I just came back from boondocking.. Weekend trip only..
New camper
Wfco 8955 converter
280 watts solar
20 amp mppt
1100 watt inverter
2800 watt kohler inverter gen ( Runs A/c on eco mode) Runs a/c and 1300 watt micro at same time. ( A/C compresser already started..)
Batts fully charged when I left off solar..
Im a heavy use guy. Had two tv's running, used toaster oven, coffee maker etc.. All off inverter.
First night no big deal as solar got back most of the power I lost..
Woke up sat to 12.3 volts batts. I have 3 - 75 ah batts in parrellel. @ on camper and third is under hood of tow vehicle. It has a second batt for camper package and solely runs off 7 pin. Starting batt not affected.
So I used maybe 100 AH. Guestimate
Was hot sat so I ran gen to run a/c and charge batts. Ran 3 hours.
Sun only available for 3 hours of so as I was in the woods.. maybe 15 amp at times.
wfco did not and would not go in bulk mode. I even tried to trick it and put a load on inverter. Gen on , then flip converter charging breaker. Nope.. 13.6 charging.. ( No 14.4.. Never seen it).
When trying to trick it, it seems like it may be going into bulk mode but the wfco kicks on and off every 10-15 seconds. I think its going off on amp overload with that 900 watt draw on inverter..
Says the bulk mode should kick on when it sees 13.2 volts at wfco terminals. Problem as soon as you hit the breaker it jumps to 13.4 volts.. Seems like it will never see said 13.2 volts..
With that said with 3 hour gen run time batts looked charges @ 12.8 volts after I turned everything off. I thought I may have overcharged...
Anyway next morning batts were 11.8 volts... I dont know what happened as we hardly used much stuff as the day before after I turned off gen and put solar away..
Disappointing..
Im trying to run tests now to see how to get this f ing thing in bulk mode..
So disappointing in this new campers converter..
But they say online this thing cranks in the amps others cant at 13.6 volts..
I dont have an amp probe...
  • Throw it in the lake. Each day that you dont do a complete charge will just make the next days worse, especially with group batteries. I'd find one that can do 14.8
  • time2roll wrote:
    Generally you need voltage to sag below 13.2 volts AT THE CONVERTER to see bulk mode.
    Not an easy task the way most RVs are wired. Much easier to just replace.
    BTDT
    Not sure I understand.
    If dry camping/generator off voltage quickly drops below 13.2 VDC.
    Heck, 12.8 is a fully charged 12 VDC battery at rest.
  • Generally you need voltage to sag below 13.2 volts AT THE CONVERTER to see bulk mode.
    BTDT
  • OK so dummy me left a heater on the inverter trying to run down batts for test.. I forgot about it.. Batts down to like 11.5 volts.. The inverter actually went off on low volts..
    Anyway I plugged into 120v and flipped converter on..
    Converter kicked on and off trying to charge battery..
    Started on/off quickly but slowly stayed on longer and longer.. Finally stayed on when batts reached 12.7 at batt terminals..
    Im monitoring now... Its on now and doesnt go off anymore..
    I dont think it when in bulk mode whether as converter terminals read 13.6..
    Hydrometer read 1150 on my ez red..
    These are good well maintained batts. No bad cells..
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
