red31
Dec 06, 2017Explorer
run 1, cum ah @ 3hrs, 54
run 2, cun ah @ 3hrs, 113
run 3, cum ah @ 3hrs, 60
Add whatever ya like to get 100%, the point is even if ya add say 10ah to run 1 and come with 65 or 70 ah AND then claim ya started @ 50%, batt cap would be 140ah, well 12.02 ain't 50% and ya scoff at 12.4 being 50% and I scoff back.
Test 2, noone knows where it started but call it 120ah from 50% and battery capacity is 240ah, BS, The only reason it went to 14.4 was it was so discharged to begin with, keep on comparing apples to oranges.
Test 3, call it a total 65ah or if started @50%, 130ah
Test 1 and 3 may be close enough to compare so compae the start amps of 32@13.6 and vs 52@14.4. That is all the wfco could do at that batt state/volatge applied and it is all the PD could do at that batt state/voltage applied.
If low volts hi amps means @13.6 the amps don't taper as fast, then no kidding cuz it ain't charging fast. run1&3, @ an hr the amps are the same, but in run 1 the cum ah is ~25ah vs ~40ah for run 3, but I still have doubts about both starting at the same discharge level, run1 was more discharged IMO.
The advantage to the PD is if ya turn it off and on it will do 14.4.
Which is more fully charged, a batt charged at 14.4 that is accepting 2A or one that is charged at 13.6v accepting 2A?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
