lawrosa
Dec 06, 2017Explorer
From Rolls Batterys troubleshooting... hey I learn something new everyday!!! :B
http://www.rollsbattery.com/wp-content/plugins/rollsbatteries/pdfs/Rolls_Battery_Manual.pdf
EQUALIZATION-CORRECTIVe
Equalization time will vary depending on the degree of sulfation and
output of the available charging source.
1. Recombination caps (Hydrocaps) should be removed during the
equalization process to allow increased hydrogen gas to escape.
Flip-top caps (Rolls R-caps) may be left on and open.
2. Equalization voltage should be set to the recommended parameter based
on system voltage. See Table 2 (a) & 2 (b) Flooded Charging Parameters.
3. Charge at a low DC current (5-10% of C20 battery capacity). If grid power is not available, use solar panels or a DC source with sufficient current when possible. At high voltages, charging with a generator may be difficult and hard on the inverter.
4. Measure and record the specific gravity of each cell in the battery bank and temperature of a test cell. If the temperature rises above 46ºC (115ºF) and approaches 52ºC (125ºF), terminate the equalization cycle. You may need to give the batteries a chance to cool off and attempt the cycle again.
Check individual cell temperatures using an IR temp sensor to isolate
possible damaged cells.
5. If cells are severely sulfated, it may take several hours for the specific gravity to rise.
6. Once the specific gravity begins to rise, the bank voltage will most likely drop, or the charging current will increase. The charging current may need to be lowered if temperature approaches 46ºC (115ºF). If the charge controller has been bypassed, it should now be used or put back in line.
7. Continue to measure specific gravity until 1.265 is reached.
8. Charge the battery bank for another 2 to 3 hours, adding distilled water as required to maintain the electrolyte above the plates.
9. Allow bank to cool - check and record the specific gravity of each cell. The gravities should be 1.265 ± 0.005 or lower. Check the cell electrolyte levels and add water if necessary.
It is recommended that a specific gravity reading of one pilot cell is measured and recorded on a regular basis when it is thought that the bank is fully charged. The measurement should be compared to previous readings. If the measurement is lower than the previous reading, a longer absorption time and/or higher voltage setting should be used. The longer the absorption time and the higher the bulk voltage,the more water will be consumed but less equalization will be required.
NOTE: The specific gravity should rise as the cells use water. Look for
trends in the specific gravity over a period of time and make small adjustments
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
