time2roll
Oct 12, 2022Nomad
sparkydave wrote:The best lies have a figment of truth. Yes if the charging system is producing 14.4 volts it may not be seen immediately. Charging at 14.4v & 55+ amps the voltage will rise very soon to 14.4 volts at the converter and maybe a little less direct on the battery terminals.
Strange thing is the manual cryptically says "although the converter is outputting 14.4 VDC, you will not be able to read that on a voltmeter due to the voltage-current relationship".
The WFCO trigger is to get voltage at the converter to sag down lower than 13.0 volts during the first minute of charging. This is virtually impassible without imposing a large load on the battery as stated above. If I hit my system with a 100+ amp load from the inverter for a few seconds the WFCO will go to boost mode every time.
To the OP: The 25 amp portable charger is an excellent solution and should serve you well.
