ElkMeadowsFun's avatar
Jun 24, 2023
What are all of these battery connections on my 17k
We bought a 2016 Nash 17K equipped with what we believe is a factory installed Cummins-Onan generator. The main control panel in the trailer has an ON switch for it, everything points to a factory install. The trailer also has 2 solar panels, one small and one larger. The 12V batteries on this trailer need to be replaced, we are curious about the number of unspecified leads to the terminals. On the positive side there is a large red cable, looks like 4 ga, we assume this is main power. Then there are 2 of what look like red 8 ga wires, one of these is the parallel connection to the other battery. We don’t know what the second one is. Lastly there is a slightly smaller red wire, maybe 10 ga, with an inline quick disconnect and 30A car type fuse spliced into it. We would really like to know about these last two – what they are and how to test for verification. We have not been able to find any schematics for this trailer. Our plan is to install a battery cutoff switch, use it as a terminal block to make these connections, label them, then wire a pair of golf cart batteries in series between the output terminals of the cutoff switch. We did this on our 2003 Arctic Fox and had good luck with it, batteries lasted much longer than the 12V marine type. Let us know what you know please.
https://photos.app.goo.gl/X3954EiXRfgeU4pH7
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
