MEXICOWANDERER
Mar 29, 2017Explorer
First I slip on the silicone o-ring.
I solder the Weather Pack pins onto the wire. Coat the pins in silicone grease and grease the o-ring. So when things are assembled, every bit of metal is overlaid with silicone grease.
If I want to get carried away, I slop on heavy duty silicone spray lube over the joined connector pair.
I'm lazy. As far as I'm concerned "repair work" means 7-year old work is like it happened "yesterday". But I use the convenient and politically correct excuse that lazily performed work that "fails too soon"is environmentally unconscionable landfill fodder. Waste of resources. Contributes to Global Climate Motormouth.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
