wa8yxm
Oct 23, 2013Explorer III
I know of basically 4 things
First, as you know reversal of the battery leads
Second A short, if he shorted the leads WITH THE CONVERTER ON (plugged in) it is possible in some cases for a converter to out just enough to pop those fuses.. Usually this indicates the wrong fuse used (IE: 2 30 amps will blow if your converter is an 80 amp, 3 won't, or 2 40s)
That short can be in 3 places.. It can be a bad circuit in the RV, or it could be shorted cells (Plural) in the battery, or it could be an accident during battery removal/replacement as described above.
(I counted it twice in my 4 both shorts in the RV and accidental install goof count as one, Shorted cells as other)
Finally Fuses sometimes fail, for no describable reason, Vibration and age is one theory,
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
