Vintage465
Jul 21, 2015Nomad
Well,the set of shelves I built are about 18" wide and 48-ish tall, made out of clear pine. So I would say it's in the neighborhood of 10 to 15 pounds hanging on the wall. It has a backing of 1/4" in cabinet grade hardwood/plywood. So I guess the good news is, that the weight is spread over a pretty wide area that I can get a lot of anchors in. The other good news is, it's being tucked into a corner so there should be something there in the corner to anchor to. I saw a pretty cool nylon anchor that really spread wide grip behind the wall board when the screw is tightened down. I just worry a little about the hard foam when the anchor spreads. The other thing I could do is put a thin strip of PL-400 sub floor glue at the top and the bottom with some kind of anchor to hold it in place til the PL-400 firms up. Problem with that is, one is pretty much married to it once the PL-400 cures and you're not removing it from the wall with out a fight and I promise the trailer will lose in the fight.
V-465
V-465
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
