naturist
Mar 07, 2020Nomad II
91% isopropanol, cheap at the local pharmacy, is soluble in both water and gasoline. So buy two quarts. Drain the gasoline as best you can, throw in the first quart of alcohol and swish around throughly, dump out, then fill with water. After solder/weld, drain, throw in the second quart of alcohol, swish, drain, and fill with gas.
Many years ago, I had to patch a hole in a gas tank with an arc welder. Didn't bother with the first quart/swish but did fill with water, which worked fine and was most helpful in not simply blowing holes in the thin sheet metal with the arc. Alcohol rinse and filled with gas, no problems.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
