RJsfishin wrote:
Don't get anything w/ the WFCO name on it, no matter what Randy says !! And don't buy anything w/o a manual override of the charging stages, and don't get anything over 45 amps if you ever thinking of charging w/ a 1000 watt Honda. A PD 9245 will still charge your batteries much faster than what you have now, and will run fine on a small genset, and you don't have to change wiring.
/\ Verified recently at 5000 feet elevation, this is a good working combination for a Honda Eu1000i, for others, though the OP might want look into an Iota, which seem to work better with Onan gen sets. My WFCO 8955 has been given it's pink slip. The PD 9245 with Charge Wizard replaced it, mounted as close to the batteries as possible, with proper heavy 6 or 8 gauge wire will get the job done.
