johnm1
Jan 12, 2017Explorer
tenbear wrote:
If you have a generator you may want larger wire than #4. I have a 3000 watt generator and it can draw 80 Amps to start. The OEM used #2 wire for the battery connections.
My generators are portable and I use my son's to do the starting.
Sam Spade wrote:johnm1 wrote:
I don't expect the truck to recharge the batteries unless it's a long day's driving and I don't even know what voltage the dual alt configuration of the 2013 GMC Duramax puts out.
To repeat:
What do you expect to GAIN by making these changes ?
Seems to me like it's impossible to answer that since you state that you don't really know what your starting point(s) are.
If you spend a ton of time and money in making "improvements", how will you know if you have really accomplished anything useful or not ???
What I expect (hope) to gain is more efficient charging from my portable generator(s). To me, efficient means faster charging and having to run them less often. It's less of a hassle and I suppose a bit of a cost savings on fuel, etc. I don't much care about the cost of upgrading the wire. It'll be an incremental cost. I'm going to replace it. So, 4 awg costs me $1.22/ft and 2 awg costs $1.54/ft. That'd be a "piddly" $16 more. BTW, 1 awg is only $2.22/ft. If I spend a little bit more to begin with, I might be able to enjoy my camping time a little bit more. That's what I'm looking for.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
