johnm1's avatar
johnm1
What determines battery cable size?
Hey all,
I'm looking into replacing the factory battery cables in the spring to hopefully get more efficient (as in shorter) generator charging time. My question is, what do I "need to do" vs. what would be "nice to do"?
1. I do not know the camper's wire size.
2. There are at least 14 crimp connectors between the 2 (6V) batteries and the "power center".
3. I have replaced ~8 of the very poorly crimped on ring connectors with real crimp battery lugs.
4. Out of the 8 replaced, I easily pulled 7 of them off with pliers with very little, to no effort.
5. I do not anticipate any heavy, or fast, battery draw downs. No inverter, no power hungry 12vdc appliance, etc.
6. I've replaced the WFCO with BestConverters Boondocker 75amp unit.
7. I have 2 Champion 2k (1.7K) invertor gennys with parallel kit to recharge as needed.
8. Right now the neg cable is screwed (self tapping screw) right to the frame near the battery and the same right near the power center.
What to do?
A. What wire size/gauge would be appropriate for my needs?
B. Should I run wire from the battery directly to the power center or replace the self tapping screws with something else more substantive?
C. The pos cable runs from the battery to some relay or circuit breaker thing (??) that's attached to the frame and exposed to the elements. Should I move it to more weather resistant area?
D. Should I install a fuse someplace to protect the batteries? If yes, what kind/size and where to put it.
E. I may, or may not, go solar. Depends upon many factors but in where we camp in NYS parks, there isn't that much sun (lots of trees) so it's not on my short list.
F. The distance from the batteries to the power center is around 20-25ft one way. This includes from the batteries down to frame and back up to the power center.
Hopefully I've listed all of the info that's needed to make proper recommendations. Let me know if I missed something.
Thanks,
John
  • I recommend pulling new #4 wire for the positive as that is about max to fit the connectors. Upgrade the ground connections as well. Though the frame is fine for the negative connection. Yes an 80 amp fuse or breaker should be near the battery. Any branch circuits should be fused according to wire size. That circuit breaker thing is probably a self resetting breaker and should be junked.
    Solar is an independent direct connection to the battery.
    Boondocker is well known to fast charge to about 75% then an extended trickle charge. If the voltage is manually controlled fine otherwise I would exchange it for Progressive Dynamics or IOTA.
  • Amp Draw and distance.
    google 12 volt wire sizing... many calculators available.
    here is just one
    http://www.engineeringtoolbox.com/amps-wire-gauge-d_730.html
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
