wires
Aug 23, 2020Explorer
TechWriter wrote:
First, go through a local sat installer, not DISH. DISH CSRs aren't RV savvy and may steer you away from using a Hopper. FYI -- many RVers are using Hoppers.
Second, go with a Hopper 3, not the previous generation Hopper ("Hopper with Sling"). The Hopper 3 is WAY superior (16 tuners instead of 3, faster processor, etc) and I think it costs exactly the same each month.
Equipment:
- Dish: 1000.2 dish with Hybrid Western Arc LNBF -- don't get the DISH Pro Plus (DPP) LNBF. The Hybrid LNBF allows you to just run a single coax from dish to RV.
- Sat Meter: either a Super Sat Buddy (eBay since it's no longer manufactured). Or it's very expensive replacement: XR-3 with the XR-TS2-02 module (about $950 total).
If you just plan to use a Hopper 3 in your RV, then the PORT 1 output from the Hybrid LNBF can be connected directly to a Hopper 3.
Thank you for the detailed reply TechWriter. This is exactly what I needed.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
