- 3_tonsExplorer IIIUsing fluid flow as an analogy, a shunt is to electrical what a flow orfice (a two sided )sensor tap) is to the measurement of fluid flow. The amperes rating is akin to the maximum expected gallons (or barrels) of flow...
3 tons - BFL13Explorer II
MEXICOWANDERER wrote:
Never a good idea to stack cables on a shunt, use....
Where does the big lug go from the buss bar to the shunt then? You are supposed to add up all the ampacities of the "branches" that go on the bar, and then have one fat wire from the buss to the next thing.
At least the 500a shunt bolt can take a 300a lug from the inverter neg plus a 100a charger's lug, and some little ones. Got to stack some somewhere!
I thought it was just on a battery post that Mex didn't like stacking lugs. - CA_TravelerExplorer IIIHere's my 500A shunt. It's not recommended to install a shunt like this near flooded batteries.
- MEXICOWANDERERExplorer
Never a good idea to stack cables on a shunt, use.... - BFL13Explorer IIAnother thing the 500a Trimetric shunt "does" is act as a negative buss bar. Then only need one lug to battery neg post.
- Big_KatunaExplorer IIFor optimum accuracy the shunt should be kept between 20-80 C. If it gets hotter the resistance can drift. That’s for Manganin shunts.
Riedon makes shunts up to 10,000 A.
I used to install 1600A, 52VDC, three phase battery charges. Usually three in parallel.
The batteries were five ft tall. 2V. For telephone offices. - MrWizardModeratoroops sorry. 75 millivolt NOT 75 ohms
brain fart - MEXICOWANDERERExplorerI was fortunate enough to find a 500 ampere shunt rated at + - 8 ppm at 50 Mv.
Gold plated everything.
It rests in a vacuum thermal sealed bag with my array of NIST traceable 1 watt resistors. And silica gel. With my 6.5 digit calibrated bench meter I can pretty much guarantee that I can calibrate amp hour meters. - ScottGNomadThere's a slight resitance across a shunt as power goes through it that creates a different voltage on each side of it. This difference in voltage is directly proportional to the amount of current that's going through it.
So as an example, 10 millivolts (.010V) of drop across the shunt is shown on the meter as 10 amps. 20 millivolts = 20 amps, etc.
My professor liked to ask his unwitting class how many types of meters there are. His answer was one; the volt meter.
The amp meter is actually a volt meter with different markings. - Needed because the ammeter is really a voltmeter.
The shunt creates a calibrated voltage drop and "ammeter" reads the voltage drop.
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
