GordonThree
Jun 04, 2016Explorer
smkettner wrote:
RV 12v cigar connectors are a size smaller than what you see in the car.
I have modified the plugs but eventually just installed a small inverter to run off the regular outlets.
x2
I think it has to do with the amperage available at that outlet. Old fashioned actual cigar lighter ports provided a lot of amps, to run the heating element. More modern 12v accessory outlets are usually limited to 5-7, maybe 10 amps if you're lucky. The outlet is supposed to not accept an actual cigar lighter device.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
