time2roll
Aug 04, 2016Nomad
pianotuna wrote:
In the case of my PD 40 amp converter PF is 0.7 so 40 amps x 14.4 volts / 0.7 = 823 watts.
Is that correct?Mandalay Parr wrote:
Actually VA times the power factor(pf) = Watts.
For practical purposes you can consider that watts is basically = to VAs
Since you converted the number using PF I believe it would be 823VA.
Wattage might be lower but the available power must be 823.
Don't forget conversion losses.
Xantrex PF whitepaper
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
