wa8yxm
Aug 05, 2016Explorer III
pianotuna wrote:
Hi all,
What exactly does 4000 VA mean in an autoformer? In a generator? In an inverter?
Thanks in advance.
It means that the Voltage times the Amps (Which by the way is NOT the same thing as Watts in this case) must not exceed 4000
For example 120 Volts times 40 amps = 4800 VA which is 800 two much
120n volts times 30 amps is 3600 VA, and thus ok
For the record 3600 VA times a power factor of 0.9 = 3240 Watts
Power factors in DC systems are always 1, but in AC systems involving Motors, Transformers or other inductive loads may be lower. Only resistive loads are PF 1.0 (light bulbs, Space/water/Fridge heaters)
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
