naturist
Jan 05, 2014Nomad II
30 amps at 120 volts is 3600 watts. So that electric heater sucks up a good chunk of your capacity. On the other hand, you are not going to be using your AC at the same time, your microwave (second biggest draw in the rig) is probably 1100 watts, so unless you insist on running heater, microwave, coffee maker (600 watts), and every light in the place (at 18 watts a pop) all at the same time, you should have no problems.
(The math is simple, add 'em up as you turn 'em on, and as long as the total is less than 3,000 watts, you got a winner. That allows room for the converter to be charging a depleted battery at the same time, over which you have no real control.)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
