past-MIdirector
Jan 05, 2014Explorer
We're a 30 AMP also and I have found running two heaters on low one at each end of the MH works good to cut down on the furnace run time. This is usually go to the upper 20. We also watch of voltmeter to make sure voltage stays above 110 volts. Low voltage in any rig with a Generator transfer switch risk burning the transfer switch out if voltage gets too low for any period of time!
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
