pianotuna
Jan 05, 2014Nomad III
Hi,
My breakout box consists of one thirty amp outlet with a 30 amp breaker on one leg, and two 20 amp outlets on two 20 amp breakers on the on the other leg. It can lead to some imbalance--but not enough to concern me, and it is more balanced than just a 50 to 30 adapter.
I use the auxiliary power cords in summer time to run the water heater and the converter. Basically I no longer need to load balance, particularly if I add the inverter into the mix.
In the summer time, if I'm boondocking and need the air conditioner I can manage to run the water heater via the inverter/battery bank and recharge later from the generator while running the air from the genny. This works well when I'm in the mountains as generator output is reduced.
I love the flexibility I have to use minimal shore power of just 15 amps while having nearly fully capacity. It is also wonderful when I can find a location that has more than one 15 amp circuit. I often do not have access to the shore power breakers, so I monitor voltage closely.
Here are the formats I can run because I chose to use standard plugs:
OEM 30 amp
#1 Aux 20 amp
#2 Aux 15 amp
Or any combination of the above it there are a sufficient number of outlets, or a 50 amp outlet.
In the winter I use the same auxiliary cords to run extra heaters. I have a watt meter installed and have seen 6500 watts flowing into the rv, or about 55 amps. It does drop down from that number after the heaters begin to cycle. I think that's a pretty good "hat trick" for a 30 amp rv! *grin*
OEM 30 amp
#1 Aux 20 amp
#2 Aux 15 amp
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
