opnspaces's avatar
opnspaces
Navigator III
Jan 20, 2018
What gauge wire from batteries to inverter
I am going to install an inverter in my trailer and am curious about what gauge wire I need to run from the batteries. To be honest I really don't have an application or device I want to run off it. I just want to do it for the "because I can" factor. I plan to mount the inverter against the front wall of the trailer so I don't imagine more that ten feet of DC wiring from batteries to inverter. Below is what I have to work with since I already own them.
A Zamp 2000 watt pure sine model ZP-2000ps. What gauge wire would I need to get optimal use from this? (Figure 10 feet from battery to inverter). This is the one I'll probably use as this is what I had in mind when I bought it.
or
a Zamp 600 watt pure sine model ZP-600ps. What gauge wire would I need if I decided to install this model instead. (Figure 10 feet from battery to inverter).
Is voltage drop a concern in this kind of setup, or is that mostly a concern with solar installs?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
