pasusan's avatar
pasusan
What gauge wire?
I want to do it right and am not afraid to dig in (do the work and spend the money).
I've got a Progressive Dynamics PD 4645 converter (which I put in to replace a boiler type).
The length of cable from the battery to the converter is 12 feet. I am supposed to double that length to look at charts for the correct gauge, right?
The gauge of the wire in there now is 8 AWG. Some of the places I look say that's OK, some say 6 AWG, and some say 4 AWG.
What do you recommend, why, and what is your source?
Thanks very much.
  • It depends on how many amps you are pulling. If your load is only 20 amps than a lighter gauge is fine. Make sure you use new connectors.
  • #8 is fine. If pulling wire go #4 as the cost is not huge and it will fit the connectors.
    Source is personal experience.
    The more you charge with a generator the more I recommend the larger wire.
    If on utility power the #8 is fine.
    afaik the most you will see for an extended period is about 40 amps with a 45a rated PD.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Winnebago installed a 45 amp converter in my RV with 8g wire with a run about 50% longer than yours.
    That said, I upgraded to a 55 amp converter and 4g wire, but that was just my personal choice. It was overkill but reduces voltage drop and doesn't hurt anything.
    ON EDIT:
    I just surfed a bunch of websites that recommend wire sizes and the results seem to be:
    8g - safe but significant voltage drop and poor charging performance
    6g - good choice
    4g - great choice because it reduces voltage drop significantly for best charging if you boondock a lot.
  • Assuming that's a 45a converter, I'd consult an ampacity chart for wire size.
Having RV issues? Connect with others who have been in your shoes.24,358 PostsLatest Activity: Feb 05, 2026
