eocamper's avatar
eocamper
What generator size works best?
My set up is ALL electric with 13,500 A/C. I am looking at a generator to run the TT while on the beach this summer. I was thinking 5,000 watts. Any input would be appreciated.
  • 3,500 run/4,000 watt surge will give you the equivalent of the 30 amp service which is what your trailer is wired for.
  • 12kw diesel generator
    Same power as 50 amp shore power
    Might get by with 5000w
    Get a pair of 3kw Honda or champion inverter generators
  • I don't know what kind of rig you have.. not sure how you ended up with an All electric unit and no generator. Is this a 50a coach with an inverter?
  • eocamper wrote:
    I'm not sure on my inverter size. As for 30 amp shore power. It works fine if I don't run too many things at once. Breakers start tripping. I had a champion 3100 watt and it worked good on my old TT which was a KZ Sportsman with the window AC type set up. I got rid of the champion cause I felt it would not run this TT.
    Depends on how much you try to run at one time.
  • I'm not sure on my inverter size. As for 30 amp shore power. It works fine if I don't run too many things at once. Breakers start tripping. I had a champion 3100 watt and it worked good on my old TT which was a KZ Sportsman with the window AC type set up. I got rid of the champion cause I felt it would not run this TT.
  • If the 5000 watt is 120/240, you may only have 2500 watts or so available to the 120 volt plug feeding the trailer.
    I understand the Champion 3100 works pretty well. But, I don't have one.
  • I hope that beach is at the ocean so the waves will drown out the racket of a 5kw generator.
  • Hi,
    See how you manage on a 15 amp shore power. If that is not enough then try a 30 amp-shore power.
    How big is the battery bank and how many watts is the inverter?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
