lenr's avatar
lenr
Explorer III
Oct 10, 2019
What good are low point drains?
What good are low point drains on a trailer that is supposed to be good for 0 degrees? My drains are solid, slightly flexible, plastic pipe. It seems like they’re going to freeze and bust at anything close to zero degrees. I do have tank heaters, but 10” of ½” pipe hanging down in cold air seems like a problem waiting to happen. All other pipes run in heated areas. I see the purpose of low point drains for folks that winterize just by blowing out with no antifreeze. However, since I use antifreeze, I see no value in the drains along with an increased risk of freeze/bust.
1) What am I going to regret if I remove the low point drains?
2) How can I keep them from freezing until I get them removed?
Thanks
  • If you don't have them how are you going to drain the tank. They will be fine and won't break
  • just fill then with antifreeze. the drains are good to get rid of the antifreeze next spring.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
