pianotuna
Feb 13, 2014Nomad III
Hi,
The web site claims 89 volts to 140 volts.
So, could this be used with a generator to "support" the start up surge for an air conditioner?
It would be a great item to hard wire to the air conditioner. Nothing else in my RV needs to be protected from low voltage.
Would it work with a modified sine wave inverter?
smkettner wrote:
Triplite Line Conditioner LC2400 will correct voltage from about 95 to 145.
Although it is only 20 amps it would keep the RV at the right voltage for conservative use.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
