pennj0321
Apr 07, 2019Explorer
BFL13 wrote:
***Link Removed***
12 and 24 volt is DC, while 110 v is AC. Your two batts in series will be 24v if they are 12v batts or else 12v if 6v golf car type (GC2)
Which do you have?
Is this for the starter battery or the house?
Usually, cig plugs are low watts with thin wires and not good for bigger DC loads, which need fatter wires to the battery bank.
My Batteries are 2,6 Volt Deep cycle lead acid wired in series, so I have 12 Volts.
They are the house Battery not the starter for the van.
OK, so, I don't want to use the cig lighter, 12 volt DC because the wires are to thin. Got it.
I'm gonna use an inverter (which changes the current to DC from AC) for the fridge.
In my manual, it says 120V- 0.72A.
Is 120V the same as 110V?
110 V is AC, regular wall outlet right?
SO at 0.72A times 110V = 79.2 Watts. Does that mean I can use my 400 watt inverter I already have?
Thanks again so much everybody for the information!
I would have responded earlier but I had to get outside and enjoy the nice weather!
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
