dougrainer
Jul 08, 2018Nomad
I use DAP Adhesive Caulk and have for over 10 years. There are 3 versions DAP makes. 1. Comes out white(so you can make sure you have filled the area gap) and dries crystal clear. SO CLEAR, that I have had customers complain I did NOT seal the areas I sealed and I had to poke it with a pen to show them it is sealed. 2. CLEAR 3. WHITE.
This is an ADHESIVE CAULK and will adhere to almost anything except a EPDM/TPO roof which you would not use this product on the roof anyway. I use it to bond wood panels inside the RV and other things that need a ADHESIVE. It bonds to the Plastic/fiberglass shower walls and will bond to Glass. I have not used Silicone sealant since I found this DAP product. Doug
PS, It does NOT flow like silicone, it is smoother and not as lumpy as silicone.
https://www.zoro.com/dap-adhesive-caulk-101-oz-clear-18242/i/G4531247/feature-product?gclid=EAIaIQobChMI2Nmk-cWP3AIV3rXACh2qZAS6EAQYAiABEgJBLvD_BwE&gclsrc=aw.ds
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
