Mike_and_Kathy_'s avatar
Oct 19, 2013
What is making my propane regulators leak?
I have a new 2013 Thor Challenger 37DT that I bought in mid-August. The dealer had it on it's sales lot for about 8 months. I have had the propane regulator replaced twice in that time for leaks in regulator. Now I smell propane again at the regulator and the regulator is all frosted over. Temp outside is in the lower 60's.
What could be making the new propane regulators leak and why is the third one frosted over? Three regulators leaking in 2 months has got to be more than a coincidence. Could there be a problem with the propane in the tank that is making the regulators leak? It has a two stage regulator.
  • We got a defective regulator that leaked in a joint that had nothing to do with being tightened. Took it back - same thing on replacement. Went to a different store, got a different brand and no problem. The defect was in a factory joint.
  • dougrainer wrote:
    The usual cause of a leaking LP regulator is just one thing----Liquid LP gets into the regulator.
    1. Overfilling the LP tank even tho it has a Auto cut off and running down the road with the tank completely full with the valve open will allow the Liquid LP to slosh into the pick up tube.
    2. Depending on the tank, the pick up tube may be welded on in the wrong place and will allow Liquid LP to get to the regulator. There some Manchester ASME tanks that have this problem. Tiffin had a few and the tanks had to be replaced. After 3 regulators, the odds are you have a defective LP tank. Doug
    What he said. Frosting of the regulator in 80 degree weather means liquid is in it, period.
  • The usual cause of a leaking LP regulator is just one thing----Liquid LP gets into the regulator.
  • It could be the model of the regulator. Look closely at the regulator, there should be a vent on the first larger portion of the unit. It should be facing down so the gas or what ever will escape down.
    MHs normally use a horizontal regulator
    Vertical regulator
    Horizontal regulator
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
