SteveAE
Aug 20, 2015Explorer
1.5 amps seems like a lot to me.
You could isolate it to determine where it is. Just pull each fuse, one at a time, to see which circuit it is mainly associated with. Once you have that, disconnect each item in that circuit, one at a time, to see what is causing it.
- Radio clock light
- Detectors
- TV antenna booster
- Ref.
Are all common culprits.
If you park your rig outside, a solar system will not only eliminate any concern about parasitic draw, but also provide power without having to resort to a generator when boondocking. But first I would identify where that power is going.
- Radio clock light
- Detectors
- Ref.
