bigfootford
Aug 20, 2015Nomad III
If you have a 12vdc radio.....It is one of the most forgotten source of drain. I installed a switch to remove all power from it.
As stated the TV antenna booster also...
If you have an inverter it is a standby amp gobbler! Turn it off.
With just the safety detectors and everything else off you should see .2 -.3 amps...
Jim
Jim
