kyle86
Aug 20, 2015Explorer
Yall are awesome! I did what some of yall suggested. Found out the tv antenna was drawing .2...
Then i pulled the fuses and found the culprits. Below are the amp draws at the battery with each individual fuse pulled.
Radio/lp det 1.2 amp
Fridge 0.4 amp
Rear 1.6 amp
Center pump 1.5 amp
Front 1.6 amp
I pulled both the lp detector/radio fuse and the fridge fuse and amp draw went to 0.1
Looks like radio/lp detector pulls 0.3-0.4 by itself
Fridge drawing 0.8 by itself... Then I found out the fridge light was stuck on !!!! Pulled the bulb and total amp draw went down to 0.7. I turned on the lp for the fridge and it went to 1.1 amps
I pulled the radio out and pulled the internal fuse for the led and presets which was only worth .1
So now that I am down to 0.7/0.8 with everything off but lp detector, I am much happier!
Gracias to all who replied!!! I will be investigating solar power and generators next! :D
Fridge 0.4 amp
Rear 1.6 amp
Center pump 1.5 amp
Front 1.6 amp
