kyle86's avatar
kyle86
What is normal parasitic DC amp draw?
My new 5th wheel is drawing 1.5 amps with all the lights, appliances, and switches off and AC main breaker off. Is this normal?
  • Here is a link to "The 12 volt side of life". It will tell you everything you want to know about batteries.
    Generally batteries should be recharged before they are discharged below 50%. Note the chart about 2/3 of the way down the above. Also note the part about surface charge, immediately below the chart.
    Coolmom42 - you beat me to it.:B
  • Go to The 12V side of Life
    for lots of great info on RV electrical systems and batteries. There is a great chart of voltage vs state of charge.
    You want your batteries to stay at 50% charge or greater (12 V or higher) to avoid long-term damage.
    With that minimum draw on a standard dealer-installed battery, you need to charge every day or possibly 2X/day.
  • When boondocking, how low do you let the batterys get before recharging? Or is a daily charging routine what people do?
    Lead-acid batteries do no like to be discharged too low (12.6v??) otherwise you shorten their life. I have a digital volt meter attached directly to the batteries to keep an eye on them.
    In my case, I charge the batteries daily. I used to tun the generator a couple of hours per day to top them up but now I have a 150W solar panel connected permanently; I prefer this solution and keeps the batteries at abut 13V all the time.
    Changing to LED bulbs made a big difference to the battery discharge rate.
    Gerry
  • I keep AC connected 24/7 . Keeps the battery charged and a charged battery has a longer life.
  • Wow thanks for the tips!! I have a dc cut off switch on the rear fuese box next to the main breaker. When cut off, the amps go to 0.01 draw. I just found it interesting/concerning that it was drawing so much with everything off.
    When boondocking, how low do you let the batterys get before recharging? Or is a daily charging routine what people do? Sorry for the newb questions, first camper :)
  • Unfortunately YES!
    Disconnect battery negative right now and leave it disconnected until you install a manual not electric chassis disconnect switch next to the batteries. Absolutely nothing should go to those batteries until the switch is flipped on. You need to turn it on for towing for brake-a-way switch function. Don't buy a garbage grade switch or you'll regret it. Delcity. Net or Genuinedealz.com both have good battery selector switches. Genuinedealz.com you can custom order a great jumper wire from the switcg to the battery.
    One week of remaining connected without being charged will destroy that battery.
  • Yes, it's called parasitic draw. Either disconnect batteries, or flip the main service switch to them off, when not in use.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
