- Dusty_RExplorerI also use a non-contact heat gun.
We once rented a car hauler trailer with tandem axels, and was hauling a little over 3000 lb. on it. After driving for a few hours I checked the tire temperatures with the heat gun. One tire was 30* hotter than the other 3, and when I checked the pressure it was 30 lb. soft.
Dusty - JohnD222ExplorerSimilar question as original poster so no new thread:
My tv G rated tires increases from 70 to 80 psi or so after a long run at 90 degree ambient. Temps rise 5 to 10 degrees above ambient. Sunny side a bit higher in both, but not a lot as long as i am rolling. All of the above is without breaking for hours.
On the other hand, all my H rated 5er tires increases from 95 to 120 psi, or so after a long run after a long run at 90 degree ambient. Temps rise 20-25 degrees above ambient 90 degrees. Sunny side a bit higher in both, but not a lot as long as i am rolling. All of the above is without breaking for hours.
After a slow coast to a stop, hubs on 5er are not hot.
All tires are inflated to proper mfg recommended cold psi for next higher load than heaviest load on tire per axle, plus 5 psi for good measure. Seems like the H rated get hotter and have more temp increase. I would have thought it would be the other way around. I would think the H's are built to take it, but wondering if this is a common observation of tv versus 5er changes en route. - MEXICOWANDERERExplorerI saw people hauling rigs at 75 mph across Arizona in 110 degree summer heat. They were dodging "gators" left and right.
- dennysbabeExplorerThanks for the input but my question was more specific to the Goodyear Marathon trailer tire fail temperature. I thought someone out there might know if its similar to the Michelin fail temperature range. I'm assuming the fail temperature could vary among tire types but maybe not. Guess I'll just leave the monitor at 158 degrees unless I hear something different.
- LynnmorExplorer II
nremtp143 wrote:
fj12ryder wrote:
FWIW I measured the tire temperature with a non-contact infra-red gun, and it measured a quite a bit hotter than the TST read-out. In the neighborhood of 15°-20°. If the TST was showing 105°, the gun was reading closer to 125°. Just was wondering if everyone else was showing the same variation.
I noticed that too, but then realized that I was measuring the actual surface of the tire and the TST is measuring the air temp inside the tire. It doesn't take long for the outside surface temp to fall while in the shade or on cooler ground such as concrete instead of asphalt. I use an infrared thermometer at each stop, and check tires at the center of the sidewall, tread and also check the hubs(especially after heavy braking). Amazing at how much difference there is in temps, even form the sidewall to the tread.
I have the same thing with my TST. One correction, it measures the temperature at the end of the valve stem, NOT inside the tire. - nremtp143Explorer
I noticed that too, but then realized that I was measuring the actual surface of the tire and the TST is measuring the air temp inside the tire. It doesn't take long for the outside surface temp to fall while in the shade or on cooler ground such as concrete instead of asphalt. I use an infrared thermometer at each stop, and check tires at the center of the sidewall, tread and also check the hubs(especially after heavy braking). Amazing at how much difference there is in temps, even form the sidewall to the tread. - fj12ryderExplorer IIIFWIW I measured the tire temperature with a non-contact infra-red gun, and it measured a quite a bit hotter than the TST read-out. In the neighborhood of 15°-20°. If the TST was showing 105°, the gun was reading closer to 125°. Just was wondering if everyone else was showing the same variation.
- Fire_InstructorExplorerMine run in the 130 to 140 degree range on a hot day and a long run. I watch my TPS closely during the day, and my pressures generally climb from the 65psi "morning-cold temp" to the 74-76 psi range. My TPS doesn't have temp feature, so I Gus use an infrared thermometer gun ($50 on-line).
- HuntindogExplorer
coolbreeze01 wrote:
I touch my tires and axle hubs with my bare hands comfortably. I'll have to use the temp gauge on them one of these trips.
Can't do that here in AZ. No idea on what the temps actually are....I just know that they are HOT!!! - ScottGNomadIt's normally cool here but the tires in the sun run 110~115 after extended running at high speed on the highway.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
