HiTech
May 12, 2013Explorer
Homeless the way you charge connected to shore power vs. stand alone will often be quite different. Though many of the 3 stage chargers out there are pretty good for both.
For you charging quickly from the genet may be important, in which case the max amps from the charger that are still comfortable within what your genet can power is a big consideration.
Since you will have beefy wires from your truck to the camper, that will be a big help in getting a great start on recharging any time you are driving (but not so great for getting fully charged).
The PD will probably do what you need unless you end up with a huge battery bank. You probably want to add the inexpensive charge wizard option.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
