Homeless_by_Cho
May 13, 2013Explorer
Westend and others,
Sorry for being such a pain in the butt but I know just enough that I am totally dangerous and completely confused.
How will I use this meter? Do I record voltage first thing each morning and watch the trend? If it is staying at a certain level, ie 12.60 volts, then I am recharging OK? Or is there some other measurement that I should be monitoring and trending? And what about the AMP reading; what do I do with that? How is an AMP reading useful to me? Where do I take these readings? My objective is to get good life out of my batteries with reasonable maintenance. Initially, I am willing to put in time to determine my battery charging needs but, eventually, I only want to do a quick check each day to verify its condition and be done with them.
I looked at both the Sears and the Fluke websites and became totally confused. I understand that one of the features of the meter is a 12VDC display to two decimal places.
1) What does it need for DC amp range? 100 amp, 200 amp, 5 amp, 10 ma?
2) Should it be a clamp-on type meter?
3) What other features do I need?
I am going to Green Bay, WI on Wednesday and they have a fair size Sears store. Maybe I can pick up the proper meter. They also have a Harbor Freight store. Someone mentioned having one of their less expensive ones. Are the requirements of this multimeter the same as above?
Thanks,
LeRoy
Thanks,
LeRoy
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
