rtaylor0830ExplorerApr 17, 2014What is the secretI need to replace the 110 tstat on my suburban water heater hoe do you get the left quarter inch screw off of the cover and how bad is replacing the stat itself
Old-BiscuitExplorer IIIApr 17, 2014Left cover screw may be obscured by gas valve.A small open end/box wrenchWith cover removed the 110V AC set of t-stats are the ones on left side.A single nut in center of bracket holds them in place
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related ContentSecret Shopper ?warranty secrets revealedSecret Switch?Hot Shot SecretCoach Net Keeping Secrets??
