Naio's avatar
Naio
Explorer II
Aug 04, 2017
What is this under my van?
When I was shopping for a new used van, I saw these on some of the ones with fiberglass tops. I figured that they had previously been wheelchair vans and it was a compressor or something for operating the lift.
But the van I ultimately bought has this thing, and it did not have a raised roof until I put one on. AFAIK, the van had one owner, who used it for towing a TT.
Like on the ex wheelchair vans with lift removed, on my van the bit that looks like an electrical junction box on a hose / cable is not attached to anything at the other end.
Whatever it is, can I remove it and put my batteries here, just behind the rear axle? There is, sadly, no space farther forward unless I go above the floor. Should I do that instead? If put them in the axle space, I will add more heat shielding on the adjacent exhaust pipe, could use advice about that, too!
Thanks you all, always.
  • Remove cover and see what is inside that box
    Hose not connected.........both ends or just one end?
  • Looks like a "three letters" remote ignition disable and satellite tracking package, likely with audio maybe even video.
  • No info on make/model/year, either in the post or in the profile. Expecting a good answer? That's unrealistic.
  • That's factory
    And possibly part of the smog/ pollution control,
    I think it's advisable to leave as is
    Somebody with more knowledge will comment
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
