3_tons
Jan 11, 2022Explorer III
Lwiddis wrote:
Interesting observations 3 tons. My 200 AH Lithium is new to me. So far very satisfactory.
Yep, the mythologies surrounding LFP’s seems to run a bit quixotic - lol…I’d again posted simply in an attempt ‘to inform’…
FWIW, for purposes of a sheer ‘wild-arse test’ only, I was also able to briefly run the microwave at even zero % SOC - this with not even a low voltage alarm on the inverter!!…My single 200 a/hr LFP load-tested out at an actual 215 a/hrs using a 500w halogen work lamp…
The uninitiated will likely have some (extreme??) difficulty wrapping their minds around this, yet they’d never seriously consider purchasing a non-Lithium portable power tool - lol
Then there’s the abundance of ‘charging myths’ (hoops??) which some suggest to be nearly insurmountable… This claim too is silly…With a standard PD, simply add a Charge Wizard (for 14.4v boost mode) and discontinue charging whenever it makes sense to you, mostly depending on one’s expected power usage - no need to routinely achieve 100% SOC…
3 tons
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
